AirBag Suspension
AirBag Suspension
Did a search here, but not much info... I just wanna make sure what is involved and what to remove and disconnect & where.
Story is, I will be removing & upgrade to normal shockers on Suberman's Liberty to Outback struts. Already have struts, coils & hats ready to be installed off from another Liberty.. On airbag based liberty - what and where do i disconnect/disable the system? Should I remove the system ie. wires/compressor & hoses or best leave it alone?
Thanks
Thanks
- vincentvega
just remove everything.
the compressor and tank probably weigh 10kg. behind the passenger guard. get rid of it.
i removed all the solenoids and lines in the engine bay but never bothered with the rear. too much work.
you can get a blank panel from a non airbag liberty to plug the hole whre the control panel used to be.
Does it involve removing the guard to access to it?vincentvega wrote:just remove everything.
remove the passenger side wheel then remove the splash pannel.AlpineRaven wrote:Does it involve removing the guard to access to it?
it all removes quite easy.
Hunter S. Thompson
Hunter S. Thompson
Sweet. Thanks guys will do that this weekend hopefully.
I'll bear that in mind. Yup not a problem.chriSTIan wrote:Unplug the switch,might start flashing if u don't
