31"
Posted: Wed Aug 13, 2008 7:32 pm
by shuffbag
i managed to pick up cheap 15" rims that i plan on running, but attached to these rims are 31" tyres.
i have 3" lifted L and understand a little chop here and there may be required but can i get them in there?:twisted:
Posted: Wed Aug 13, 2008 7:36 pm
by AndrewT
Short answer: "no"
Slightly longer answer: Fatz has 6" lift kit, Subaru Outback struts, massive 2" wheel spacers, quite a lot of guard chopping, fairly wide offset rims....and the 31's don't fit - still can't get near full lock on turning.
I'm planning on running 29" tyres with my 6" lift kit, they should juuuust fit.
Posted: Wed Aug 13, 2008 7:38 pm
by D3V1L
i hope ur good with a grinder
dave
Posted: Wed Aug 13, 2008 7:41 pm
by Matatak
youll have major clearance issues with them.
particularly against the firewall i expect
go for 29's max i say
what rims are they?
Posted: Wed Aug 13, 2008 7:54 pm
by amuck
Hi mate,
I'm running a 3" lift with 215x80x15 which comes to ~28.5". I had to cut the front guards and beat the seam on the firewall flat to stop the rubbing. On the back it just catches on the rear of the wheel arch when hitting a big dip in the road.
Any bigger than about 29" you'd have to make major alterations to the firewall.
Hope that helps
Cheers Rob
Posted: Wed Aug 13, 2008 8:20 pm
by Subafury
lets see some pix
Posted: Wed Aug 13, 2008 8:21 pm
by Alex
dreaming abit
it WILL hit massively on the firewall.
Posted: Wed Aug 13, 2008 8:43 pm
by shuffbag
truth be told my car is mainly a daily driver and unless its some local urban mud my car just might not see it, with all this said all i wanted was 15" wheels with some normal road tyres.
but the 15" wheels were attached to the 31" monsters and after sitting them next to my car and wondering, i just had to ask? would be good... might still try.... my cars just asking for a yellow sticker even with out them.
i'll duck out side place one next to the car take a photo and up load it on here.
back in 5
Posted: Wed Aug 13, 2008 9:02 pm
by shuffbag
well *cough* theres not that much size differance
oh and my tyres on atm are 185/75/14
might make for a fun sunday arvo. i don't want to alter to much of the visable body as i will never run tyres of this size once there gone/ if they get on at all
Posted: Wed Aug 13, 2008 9:14 pm
by Fatz
31s definatly wont fit with excessive chopping of guard and firewall. They fit fine stitting there straight, but as soon as u get spring compression and turning, it will rub like a mofo.
im planning on changin my 31x10.5 to 30x9. With the cutting that i have done, they should fit without any issues.
If you really want 31s prepare to massacre ur soobie, and get alot of unwanted attention.
As a daily driver thats just stupid, youll drink way too much fuel, and youll need a 4.44 ratio to get anywhere
Posted: Wed Aug 13, 2008 9:19 pm
by shuffbag
well regardless im doing a six stud conversion this weekend, might put them on for a just for a look then have the tyres removed. my diffs are 3.9
Posted: Wed Aug 13, 2008 9:23 pm
by Fatz
doubt theyll fit
Posted: Wed Aug 13, 2008 9:24 pm
by BrennyV
hah, ill stick to my bfg 27's do the job well
Posted: Wed Aug 13, 2008 9:26 pm
by Fatz
tho id love to see an 82 try and pull some 31s.
hahahah
Posted: Wed Aug 13, 2008 9:33 pm
by shuffbag
EJ
unless your talking in genral
by AlpineRaven
Won't fit and you're wasting your time, - you wouldn't be able to have good steering in some corners.... *smash....
thats my 2c worth.
Posted: Wed Aug 13, 2008 9:39 pm
by shuffbag
partialy deflated i toyed around with them at u-pull it, almost got one on to the rear of a 2wd L sedan (forgot a hammer couldn't knock 2 studs out of the hub with a shifter ) was hiting the 1/4 not that it could have been driven with it on there anyways.
Posted: Wed Aug 13, 2008 9:42 pm
by shuffbag
its not a wast of time, my main objective was the rims+6 stud conversion. i know they could be made to fit (if i was to go that way, the tyres were just a bonus) but i was wondering how hard it was to do. and wouldn't steering mainly be affected by the rim offset combined with the tyre?
