lib buying info wanted
coupe
Post by coupe » Tue Aug 05, 2008 10:19 pm
Hi Gang
Im buying a 1994 Lib wagon for my son.
Is there anything i need to look for when checking it out
Thanks Pete
Use The Fork Luke
seagull
Post by seagull » Wed Aug 06, 2008 1:58 am
Turbo or non turbo Pete ??
not gray is it ?
Post by AlpineRaven » Wed Aug 06, 2008 7:08 am
as 1994 wagon - there is two different types of Liberty - Generation 1 or Generation 2? (Generation 2 is a newer shape than Gen 1) Which one are you talking about?
Liberty/Subaru are reliable cars if you look after them then they'll look after you. What to check out - Service books is very important and when last time timing belt has been changed? apart from that, normal overall checks would be required.
Bumpty
Post by Bumpty » Wed Aug 06, 2008 3:22 pm
Should have a sticky of the most common models of Subarus, whats unique to every second hand model haha, A couple of threads are popping up now :)
Thalass
Post by Thalass » Wed Aug 06, 2008 4:07 pm
Do the liberties have the same rust issue under the doors as the L did? I'd take a peek under there, but I'd look underneath the car anyway so it wouldn't be out of my way.
coupe
Post by coupe » Wed Aug 06, 2008 6:15 pm
Thanks Guys
Its a gen 1 5speed awd, non turbo, silver. reasonable kms
they want 3100 ono
cheers Pete
Use The Fork Luke
Post by AlpineRaven » Wed Aug 06, 2008 7:56 pm
No normally they dont, ive seen one really badly rusted up in Queensland was a surfer's car with salt etc on the Liberty - that was on ebay.
One Gen2 Liberty sedan I saw about 2 yrs ago had rust on top under the window seal due dirt build up and not cleaning properly.
Apart from that not that I know there isnt any rust. But dont forget you're in WA so might be different than here.
