HELP me post a signature pic P L E A S E ..
It is late Sunday night and I am trying to post up a signature pic in the User CP section.
It has not worked
I have used imageshack and got an address
I have also browsed my PC directly and got the photo in but it don't save
any experienced tips
I have never tried this one before, just survived with text sig, time to advance my skills
THANKS
It has not worked
THANKS
that is WHAT I was trying to achieve
edit : I should explain here that in the post above Matatak replaced his Subies photo with mine for just a momemt and fixed it up soon after to show his beast again, reading this post in real time you woulda seen my photo above edit done
So, you got it to show up WELL DONE !!
Now for your next trick it needs to come up as my signature
What do you suggest i try
I tried the other url begin in lower case and it come up as invalid file
i got that in there by using this code below
[IMG]http://img405.imageshack.us/img405/915/grumpytw4.jpg[/IMG ]
take the space out as the second last letter and just paste it in there.
Wagon is no longer....
HEY MATATAK, IT WORKS
I removed the space from the URL pasted in the text window and that seems to have solved the problem. I don't think it needed to be in the options windows below at all once the image shows up as current
My excuse is it coming up twenty years since i have had to spot errors in code and that was pre (historic) Windows
