cargo barrier dillema?
hi all. im trying to fit my cargo barrier into my L series wagon behind the 1st row (driver/passenger) and cant figure out how to bolt the lower support braces in? does anyone have any pics or diagrams that can show me what goes where?
any info would be helpful????
if its not native its not cool.....
What brand of cargo barrier??
http://www.subiparts.com.au
0438 887 746
0438 887 746
There should be two long straps on the bottom. The mount to the same holes as if it was in the rear (cargo area) position. The top mounts are where the hand grab is above the doors. I will try to dig up some fitting instructions / take a photo of mine.
0438 887 746
0438 887 746
- sven '2'
should have two pieces of angled flat bar about 200mm long, left and right for the lower mounts.
On the strut towers from the inside the cabin, you will see a grommet that holds the plastic trim in place, about 20mm off the floor. Drill these out with 13mm bit, HT bolt in and you're done.
If it takes more than 1-2 beers there is somethng a miss!
NB: Milford made a couple of variants over the years for the L-Series - if you are still in strife i have a contact who works at milford
sven
sven
