Post
by ronsue » Mon Feb 28, 2011 2:04 pm
Hi all, i have also had the "Shudder" problem. I'm relieved it's not just me and can be more confident next time I tell them about it. I have not had the shudder as regular as some of you but it nearly always occurs in 6th gear doing over 100k/ph on a flat road when I start to go up a slight incline, it loses power, the speed drops right off and I have to change gears down before I can increase speed again. It's not much of an incline and should easily coast by in 6th. It has happened to me once in a lower gear, 4th I think, and was really bad and obvious to all in the car. It did not happen for a few weeks, then got it again at usual spot, just after that the DPF light started flashing and 3 other lights came on as well. Took it to closest Subaru Dealer and the DPF soot accumulation was at 135% They did regen and was told it was not covered under warranty. They did the service as well cause he said that i would need oil replaced etc anyway. I had 20,000k on clock and was not due for another 5000k/2 months. I had no warning before this. The DPF light has only come on once before for a few minutes only, just a few days after the 12500 service. Have found your forum while looking up info on the Diesel Particulate Filter. the service guy said it needs to be driven at higher revs to burn soot, at least 15 mins continous driving without braking to clean dpf regularly. I think the shudder may be linked to the DPF?
I'm really annoyed they have not fixed this under warranty, I feel I have not done anything wrong, have had service on time, had no warning then suddenly light flashing. They have not said you have to drive at high revs when we bought the car and the light has not been coming on to show that it needs a burn.
