Who else is waiting for Sam's twin carb twin port ?
Post by NachaLuva » Tue Dec 18, 2012 8:29 pm
Silverbullet wrote:Haha you're right Jonno I went away, had a rest and a cuppa and went out there to finish the job. It's in!
Awesome :mrgreen:
Brumby Kid
Post by Brumby Kid » Tue Dec 18, 2012 9:07 pm
Silverbullet wrote: Getting it in and getting it running will be 2 completely different things, hopefully there's nothing too complicated to sort out in regards to emissions stuff.
What emissions stuff?
Haha lol.
FINALLY got mine running with the weber this afternoon.
Just a few little things to tidy up, then run her in and il be all ready for our drag.
Cam
Dads Car: 02 Impreza WRX STi
Post by Silverbullet » Tue Dec 18, 2012 9:30 pm
Good to hear Cam! If you want to race my car as is, it will have to be the day before rego expires so it doesn't matter when my old worn gearbox explodes :rolleyes:
Brumby Kid
Post by Brumby Kid » Tue Dec 18, 2012 10:14 pm
Haha, I might have a chance then.
This will be very interdasting.
nncoolg
Post by nncoolg » Tue Dec 18, 2012 10:26 pm
Next time someone is getting rid of a gearbox, ask for the input shaft, perfect aligning tool.
# EA82 AWD 4EAT,
Post by steptoe » Tue Dec 18, 2012 11:14 pm
Buy a clutch from the US with exedy name on the box and they come with a splined plastic alignment tool - another nice touch buyin' somethin' from the States :)
Or if you are lucky the part is available here in splined plastic
Post by Silverbullet » Tue Dec 18, 2012 11:29 pm
Old input shaft would be ideal, otherwise I was going to hunt around for the purpose made splined plastic ones.
Post by NachaLuva » Tue Dec 18, 2012 11:34 pm
nncoolg wrote:Next time someone is getting rid of a gearbox, ask for the input shaft, perfect aligning tool.
Not a bad idea ;)
Steptoe, are the Exeedy clutches available here or would you have to import it?
The US really do get a better deal than us, esp on the price of identical TBelts. I'm up for my Tbelt soon, will most likely ship it from the states to save some $$$
Post by steptoe » Wed Dec 19, 2012 7:54 am
Yeah exceedy here but not ever seen a tool come through with any brand of clutch kits for anything. My thoughts on clutch kits from US is freight is a killer to get it here. To negotiate and pester local supplier for a keen price could be pretty close and less trouble when something arrives broken - like the little spring retainer clips ear on throwout bearing carrier :(
Post by Silverbullet » Wed Dec 19, 2012 3:51 pm
Sorting out my hoses today and figuring out what's what on the inlet manifold. The crossover pipe is quite corroded (the one coming from thermostat housing) but still usable. Looks like this part is pressed into the manifold, so what can I do to preserve it and prevent it from rusting further? Also all of the tiny coolant outlets poking out of the block and manifold are in similar condition, also pressed in. I think I'll replace these with threaded brass connections when I come to doing the car properly.
Then there's the issue of all 6 manifold bolts gone missing in the 9 months of inaction :( Will any M8 bolts of correct length work? The originals are always that goldie color which I always associated with the high tensile bolts, but the way they snap so easily suggests otherwise :eek:
Post by Silverbullet » Wed Dec 19, 2012 5:38 pm
Never mind, this engine won't be running any time soon. In fact now it has to come out again and be completely torn down; distributor gear has been destroyed.
Since I couldn't put the manifold on I decided to align the dizzy and install it, pretty easy you'd think. I turned the engine over by hand till #1 was at TDC and did the usual thing with the dizzy moving it to slightly before #1 fires so when the gear slides in it all lines up. It went in without a problem, great. Put in the single hold down bolt and all was well. Then I turned the engine over by hand 1 revolution of the dizzy. About half way through the dizzy started to get pushed out, bending the holding down plate. Strange I thought so I pulled the dizzy out again and the gear at bottom was covered in metal shavings and big burrs pushed up around the edge of each tooth... :-|
Looked down the hole and there's a neat pile of shavings next to the gear in which every tooth is completely destroyed, with a big chunk missing to boot :cry:
What the F#@K just happened!?!?!? :evil:
Sorry Cam, drag race will have to wait.
Post by steptoe » Wed Dec 19, 2012 5:43 pm
:cry: near holding back tears, have to go back and reread your last post :cry:
What is it with you and religeous events ?!
The goldy colour is gold zinc me thinks, and any M8 same pitch will do. I have some stainless studs I use to align spider manifold, then remove and fit correct bolts.
going back to reread....
Post by steptoe » Wed Dec 19, 2012 5:54 pm
OK, seen this in 4.0 litre Falcon engines when aftermarket distributors have gone in as a fix to stuffed factory dizzy on EL. Was seeing a few a year and one engine swap centre guru worked out it was in the drive cog and think was swapping the old factory dizzys cog onto new aftermarket. He was making money from this problem so never reported his suspicions.
The dizzy cog must be harder than the jack shaft as it is another jack shaft needed to fix and a factory dizzy from the wrecker
These donks had a dinosaur link in that even though they were OHC, still had a jack shaft to drive dizy and oil pump.
As for what happened to yours , as you describe it was pushed up and out of the block bending the hold down plate.
Gona try and make you feel a little better ....with my last EA81 rebuild, discovered my torque wrench was falling to bits after it was all in and running - had nightymares about the conrod bolts to head bolt tensions. Pulled it all down again to find all was fine. On assembly I turned crank with one hand, finger was too close to cam/crank meshing gears and the uncut speedisleeve was there to help squash and slice my finger at the same time.
Effin, blood coming out of me in bulk, wrapped dirty rag tight ! and drove self to hospital. Think I really coulda done with the O2 before I got there, got it as soon as they saw me and when the stitches came out !!
Post by steptoe » Wed Dec 19, 2012 5:58 pm
teeth gone off dizzy or the camshaft ?
you've only turned it by hand and not by crank or even run it, and you have pile of shavings ?
Was it , nah, stupid question, as it would have been correctly seated if you got the hold down clamp on and done up ....
:cry:
Post by steptoe » Wed Dec 19, 2012 5:59 pm
not wanting to rub it in, but are you in a condition to take pics
Post by Silverbullet » Wed Dec 19, 2012 6:36 pm
Yep just one revolution of the dizzy by hand. I thought maybe the drive cog on the crankshaft was back to front, but checking the old engine they look to be the same orientation. It's the gear on the crankshaft that is destroyed.
Pics don't show much, but my tiny camera on a bendy stick shows it perfectly; there's hardly anything left of the teeth on the crank. Only thing I can think of is maybe the electronic dizzy and points based are different? I was using the points based dizzy for ease of setup (I thought) and I'm not familiar with electronic, and no coil to suit either. But the shaft length and gears are exactly the same on both, same number of teeth, teeth slope in the same direction. Please don't tell me there's some indiscernible difference between the two I don't know about.
Post by steptoe » Wed Dec 19, 2012 6:46 pm
testing my EA81 knowledge here....crank drives dizzy , hmmmm ?? I recall cam and crank meshing at the engines rear ...gees been playing EA82s too much .....
Man, what you say sounds impossible, half a crank by hand and minced metal ??
I believe you but shakin' head in disbelief
Post by Silverbullet » Wed Dec 19, 2012 7:07 pm
Yeah the gears for the camshaft are at the back but the distributor gear is at the front on the crankshaft. I'm at a loss as well, I thought these gears were hardened steel and to be completely destroyed in one turn...doesn't make any sense. I didn't feel anything unusual when turning it over either, just went around smoothly and this was the result.
But I'm glad I find this now instead of when firing the engine up for the first time...imagine the carnage :-|
Post by TOONGA » Wed Dec 19, 2012 7:34 pm
points dizzy and electronic dizzy are a straight swap in the ea81 motors. is the cog on that dizzy straight toothed or shaped?
sounds mighty odd
Post by Silverbullet » Wed Dec 19, 2012 8:16 pm
TOONGA wrote:points dizzy and electronic dizzy are a straight swap in the ea81 motors. is the cog on that dizzy straight toothed or shaped?
sounds mighty odd
Both the electronic and points dizzy's are shaped (spiral gears?) The electronic dizzy was on this engine originally, comparing the two they are all but identical apart from a small difference in the shape of the location shaft (alloy part)
Like I said I've installed a dizzy on these engines more than once. I didn't do anything differently so there must have been something wrong with the engine to begin with, but the gear looks the same orientation as my old engine ruling out the back-to-front possibility.
