how to convert to 5 stud
tambox
Post by tambox » Tue Sep 02, 2014 6:20 pm
I agree with the idea of pre-heating the whole thing before you weld it, as welding it cold would put stresses on points. You would also need the correct rods/wire to suit this sort of work.
There is info on the net about how to pre-heat, pre-welding and how to weld it and what with.
Just remember, you are playing with the bit that holds the wheels on your car.
L serious, still.
Post by AndrewT » Tue Sep 02, 2014 10:04 pm
For the plugs you could drill the original holes a bit larger to suit slighly larger rod rather than trying to get rod exactly the right size.
End of the day no cop would ever be able to tell by looking, nor would know/care that L's originally had 4 studs unless they're an enthusiast. But still, i'd rather use new hubs than modifying originals, its a better solution.
henpecked
Post by henpecked » Tue Sep 02, 2014 11:37 pm
AndrewT wrote: But still, i'd rather use new hubs than modifying originals, its a better solution.
Blank hubs ?? where would you get them, or are you referring to using C----D's conversion kits ?
Post by AndrewT » Wed Sep 03, 2014 2:08 am
Yes that is what I am referring to. I run a pair of Cr0ssBread rear hubs myself, although I don't think he supplies them any more. RSR555 Paul has a line on getting similar hubs made I believe, and really anyone could get an engineering / metalwork place to make something up given some plans or an example. I have a couple of clients in this field, I should give them my hubs and see what it'd cost to replicate.
Willy Fisterbottom
Post by Willy Fisterbottom » Wed Sep 03, 2014 7:55 am
You gonna copy my rear hubs Paul?
Post by El_Freddo » Sun Sep 07, 2014 12:42 am
I think he's going with new ones Willy.
How have yours been holding up? Would they pass by an engineer's report without issue?
Willy Fisterbottom
Post by Willy Fisterbottom » Tue Sep 09, 2014 5:45 pm
Mine have been on the car for 10 years without any drama. I can't see any problem getting it engineered, I never bothered trying to get it done.
Post by TOONGA » Tue Sep 09, 2014 6:54 pm
Talking of illegal here is another way to get 5 stud on your 4 stud hubs
http://www.ultimatesubaru.org/forum/top ... -adapters/
Post by TOONGA » Sat Sep 20, 2014 9:26 am
TOONGA wrote:Talking of illegal here is another way to get 5 stud on your 4 stud hubs
I have noticed interest in these adaptors from Australian members of USMB is there a machinist amongst us who wants to make some sets of the "Offroad only" adaptors up?
Post by AndrewT » Sat Sep 20, 2014 12:31 pm
But using adaptors just reduces the 5stud advantage to being able to use 5x100 wheels. Pretty much the whole point of 5stud conversion is the substantial brake upgrade.
Post by TOONGA » Sat Sep 20, 2014 4:08 pm
If you need the brake upgrade, some people just want the choice of 5 stud wheels.
Post by AndrewT » Sat Sep 20, 2014 7:45 pm
Here I am with the opposite problem. I have 5stud hubs but want to run Sunraysers!
Proton mouse
Post by Proton mouse » Sun Sep 21, 2014 8:03 pm
That's a terrible problem AndrewT :o
You would never be able to sell the 5 stud hubs :rolleyes:
Best if you just send them over to me and I will send you some way better 4 stud hubs in return so you can run some sunnies!
I'll even pay freight :D
Post by El_Freddo » Sun Oct 19, 2014 10:25 pm
The 5 stud swap is one thing that's holding me back from an EJ brake conversion - I'm "committed" to the scorpions :rolleyes:
Those adaptors made of aluminium! Made to "internet standards"??? WTF??
dfoyl
Post by dfoyl » Mon Oct 20, 2014 5:10 pm
FWIW, there's a guy on USMB selling a pair of hubs (and ONLY hubs) from an XT6 for $300 US at the moment. No backing plates, no rotors, etc. I am guessing rotors could be obtained here with searching (otherwise import from rockauto for about $30 a piece, being careful to get rear AWD and not FWD), not sure on the backing plates...I think the X-**** kit used the XT6 plates modified, with Liberty calipers ?
Post by TOONGA » Mon Oct 20, 2014 7:38 pm
The X-.... kit used liberty backing plates modified and liberty calipers. 300 dollars + shipping is expensive but Subaru would want way more if they had them in stock Ex Japan.
taza
Post by taza » Mon Oct 20, 2014 8:17 pm
Havings just bought a L series with ej22, awd (sf foz box) and 5 stud cr00s**** kit with foz brakes Id say the brakes are the best part.
Cr0ss**** don't make the kits anymore unfortunately. Thus I bought a whole car, running and licenced for half the price of the kit.
dfoyl
Post by dfoyl » Tue Oct 21, 2014 11:40 am
Ok, so combining the last two posts. I can put modified SF Foz rear brake mounting plates, SF Foz rear brake calipers on XT6 hubs, on to a Brumby ? I have a SF Forester here I am wrecking, so with the XT6 hubs - and some new rotors - I have everything I need ?
stenno
Post by stenno » Tue Oct 21, 2014 5:27 pm
Yes. You need to drill a few holes in the forester backing plate to match the the brumby bolt pattern. Rotate the plates a little for hand brake cable clearance before you drill. I welded some washers over the new holes for some extra "support" when I did this.
Don't forget to take photos of how the handbrake drum goes together in case you forget when reassembly time comes.
dfoyl
Post by dfoyl » Tue Oct 21, 2014 7:22 pm
Thanks, sounds like a plan. Still trying to track down some rotors, the local Repco and Bursons stopped as soon as I said Subaru XT6, JDM and US only (Bursons at least said they would try to find something if I can provide the specs, Repco just gave up).
