EA82 + Hills = :(
speaking of being reminded, once ran a Holley 465 that had an open to the atmosphere float chamber vent which is how I assume a bit of glass or silica got into the float bowl and drift towards the main jet when I needed the power and bog me down, back off and the fuel flow dropped back and so did the little sucker. Another bad thing I did with a Holley was to fit the brass plate anti splash device on the wrong side of the bowl gasket. It was wedge shaped and well, fell off its pins & wedged itself under the float holding it shut going up slight inclines. Once fuel was used up, chamber was empty, no go. Stopped on a busy road outside Ford dealer where I had recently bought pump. I tested pump incorrectly in a hurry with traffic up my rr's all the time, blamed pump, politely tried to get it replaced under warranty. One legged spare parts manager, knew I was a long time customer and in the trade at the time denied replacement and not want to help me.
For his amusement, I never went back to that dealership for anything.
Cant remember the part no, but its a repco, one way, plastic one. Last time I got one from KMart.someguy wrote:Thanks for the tips.
Carb is fine.
Will check out the fuel filter/lines one night this week when its less wet :P
Does anyone know what model/part number the fuel filter is incase I need to pick one up during the week?
Speaking about carb jets, it is possible that one of your jets is blocked up of course, which would mean a carb rebuild.
Also, is your a manual gear box?
hope that was it..................
whats going on about your my??
pickstock racing fabrication
pickstock racing photography
GETDIRTYCLOTHING
GETDIRTYCLOTHING
great to see an easy fix, people always seem to shout out - it's your fuel filter(s), this time they were correct. Some motorists get these symptoms, book car in for a service and come out with a few hundred dollar service and tune - all for just a blocked fuel filter. Now, did you buy a spare, or at least right part number on underside of bonnet with a marker or vegemite
AND thanks for following up with solution.
This is exactly what happened to me a while ago, except the service was closer to the thousand mark, I was dumbfounded that they gave it back to me saying problem solved and I barely made it up the hill on the way home. Pulled the filters and found I couldn't blow through them, $20 later, problem solved. Mighty angry.steptoe wrote:Some motorists get these symptoms, book car in for a service and come out with a few hundred dollar service and tune - all for just a blocked fuel filter.
Glad it was your filters, I'll look for a wagon screaming down the freeway now, whilst I'm chugging along not overtaking crap.
- sven '2'
True, but always start with the basics. Once these are covered off, start looking for odd-ball reasonssteptoe wrote:great to see an easy fix, people always seem to shout out - it's your fuel filter(s), this time they were correct.
To do so otherwise simply angers the car god - and he can be vengeful fcuker.
And I think everyone around here has been owned by him at some point
Sven
