Jealous on so many levelshenpecked wrote:Quite a lot got done Friday, mostly ( actually all [;)] ) by a fellow member
WIC got
1) repaired drivers side electric window motor ( replaced entire assembly)
2) rims and lyres - 195/60/15s
2) New rear disk Brakes
4) Rear LSD
I just need to put the OEM racks on, the 2" lift and steering extension, the rear window louvre, fix up the aerial and speakers, and put proper coolant in the new alloy radiator and its all good to go start work on the Brumby:D
1. Your paint job is in better nick than mine
2. Discs on the rear
3. Nice alloys
4. You didn't have the stupid screw on roof luggage racks so you didn't need to remove them and fix the holes.
5. Alloy radiator
Just for interest, what is the paint code for the car ?
The sticker should be on the shroud above the top of the radiator at the front of the car when you open the bonnet.
Well done with all the mods.
no shroud - so no paint code on either the wagon or the brumby ( both silver) - sorryCliff R wrote:Jealous on so many levels
3. Nice alloys
5. Alloy radiator
don't be J re the paint, the wagon has rust corner on the hatch , and two on the windsreen, and fade and chips all over on both cars.
- TOONGA
I got 4 "new" tyres 215/65/14 fitted to my straightest rims (took some doing) for a total cost of 200 dollars. the front 2 are brand new and the rears are 90% 30 dollars each, 20 dollars each to fit and balance. (including tyre disposal) No more vibrating steering wheel or 4 wheel drifting in the wet.
As well I finally got my alloy bash plate in place. as agricultural as it looks I can jack the car up using the alloy C bar brace/lift block?
(not that I will unless I have to)
- TOONGA
Yeah I did have a black set on the Vortex but the white ones look way better.
The bash plate is from an impreza of some decription, from memory it is written on the engine side of it. The aluminium C channel came from the recycle/scrap bin at work.
The hardest part was cutting the angles using a very small vice and a hacksaw.
- Brumby_ProjectX
Wagon
Got its A/C pulley replaced with a new bearing (CBC Adelaide $17) and a big and solid (6mm steel tube) - "don't park close to me" tow bar to intimidate the tailgaiters that Adelaide roads are infested with.
wanted to have it on the Brumby - but it won't fit.
Thanks to a forum member for getting this done for me, ( I did the bearing replacement using the baering freeze and pulley on the BBQ tip on the other thread.
New LCA, radius rod and sway bar bushes in the front of the MY wagon. Old ones were Rooted, it was playing havoc on my camber and chewing out my tires. Now they are neutral if not slightly negative, certainly close enough for me to adjust. Took a bit longer then I wanted but wasn't really hard. Certainly worth it if it saves me getting new tires prematurely.
Doug
Doug
The silver Brumby finally got its rear disks , LSD and bash plate this week, and a bit of S/S and Doggy "bling".
rears
right
and left
AND the LSD and Bash Plate
and a S/S Tourneau brace
and here are the Australian Cattle dog passengers.
Dash is a red heeler , with more show ribbons than you can believe ,a full "Australian champion" show dog, she was just a few hundred points away from "Grand Australian Champion" status when the previous owner retired her from showing..
The 17 week old puppy has no papers but has two very hard working blue heeler parents, - what more could you want than a "bluey" born on Australia Day ??
The tourneau also got re-stitched
The to do list is getting shorter,
for the Brumby its
1) window tint replacement
2) full bull bar
3) door dynamatting with 6x9 speakers, power windows and central locking and fix passenger ext handle
4) power steering
5) analogue cluster w Touring wagon dash and central console
6) HID lights
7) stronger reversing lights
8 ) forester seats
9) 280zx power door mirrors
10) alloy radiator
11) 2" lift blocks
12 longer action front struts w camber tops
13) longer action rear shocks
15) ej20 on original 4 speed, unless silverbullet is successful with using the MY 4x4 actuator arm with a L 5-speed box.
have all the parts ( except longer rear shocks) just short time, health and mechanical ability
rears
right
and left
for the Brumby its
2) full bull bar
4) power steering
6) HID lights
8 ) forester seats
10) alloy radiator
11) 2" lift blocks
What brand did you use and what is your impression of them?Subydoug wrote:New LCA, radius rod and sway bar bushes in the front of the MY wagon. Old ones were Rooted, it was playing havoc on my camber and chewing out my tires. Now they are neutral if not slightly negative, certainly close enough for me to adjust. Took a bit longer then I wanted but wasn't really hard. Certainly worth it if it saves me getting new tires prematurely.
Doug
# EA82 AWD 4EAT,
If you have them please PM me
# EA82 AWD 4EAT,
The sway bar mounts and sway bar-radius rod bushes were Nolathane branded. I actually got the links a few months ago (so I don't have the packet for the part #) because the passenger side had herniated out of the side and was clacking away. The LCA and Radius rod bushes I go off ebay a week or so ago. The LCA bushes are Superpro bushes (SPF1097K) and the radius rod brand was Whiteline (W81061).
The Nolathane bushes all fit pretty well bang on. The ones that have been in for a month or so haven't fallen apart. Seem fit for the job.
The Whiteline Radius rod bushes were significantly different to what was in there, however they fit and flexed enough. I cant really comment on there reliability as they have done about 5km's
The Super pro LCA's were a little bit questionable. They were different to what was in there. The ones in the LCA were a single bush with a metal sleeve and a metal crush tube. The super pro ones were a two piece bush that went in from each side and a crush tube thru the middle, but no metal sleeve. This meant I had to remove the old metal sleeve ( old rubber bush basically pulled apart). It was too tight for the threaded rod, big socket and washer trick so I had to cut it carefully with a hacksaw. Once cut it slid right out.
The new super pro bushes fitted hand pressure tight into the LCA. The biggest problem with them was the large flanged end they had, probably 3mm thick on each side. This meant they didn't fit nicely into the bracket on the cross member. It also meant that a significant amount of squashing would have to take place for the crush tube that was the right length to clamp down hard with steel on steel. I ended up bending (dont do this on your car!) the bracket open a touch and hammering the LCA up into position. When tightened back up it all clamped up fine and my suspension still moves up and down so it cant be too tight
So meh, it worked but maybe alternative brands will be better.
Doug
Doug
Silver Brumby Pw steering and dual bash plates
Put in power steering and doubled up the front bash plate. so one less scheduled job and one less unscheduled job.
