Post
by AlpineRaven » Wed Aug 06, 2008 9:21 pm
Heh congratulations on your buy of this Liberty, Sounds good.. Its normal for them to be "low" in rears, if you're going to tow a trailer everyday basics I suggest you to upgrade to Kings heavy duty rear suspensions and will handle better than before..
Fuel Gauge... is common problem with Liberty - on the sensor unit is at fault - they're poor quaility contacts inside it, a lot of people here tried cleaning, sand it back so on and never get good results as the problems comes back in couple of weeks. You have two choices - get new one but the price is............ $$$$$! Since you have AWD, there is 2 sensors inside the tank (left and right) and will cost you around $500 to replace.
2nd choice is to rely on your fuel light & kilometres, every time you fill up at the servo you should reset the ODO button on the dash, and for EJ22 Liberty should last upto average 550kms So if you reach 500-525kms its time to re-fuel soon...
I rely on mine with this option, (when I go beyond 200kms it drops down to Empty) mine comes on at around 520 - 540kms when the light comes on, and normally lasts me for another 60-80kms depending the conditions (highway/city etc). I managed to run to empty at 665kms once and had fuel can with me.
1996 Liberty Wagon - SkiFX AWD 5MT D/R, Lifted.. Outback Sway Bar, 1.59:1 Low Gearing see thread:
1.59:1 in EJ Box Page
![Image](http://i14.photobucket.com/albums/a313/tmerritt/PICT0927.jpg)
