Don't have a manual for the car
 Can you fit a child restraint ?  If so, where are the anchor points in the back ?
  Can you fit a child restraint ?  If so, where are the anchor points in the back ?Thanks,
Mike.
  Can you fit a child restraint ?  If so, where are the anchor points in the back ?correct. mine has the holes but no nuts. kid bolt is in the floor on mine.RSR 555 wrote:From what I can recall, the anchor points are on the roof lining, just forward of the rear tailgate. There was three plastic plugs that you could pull out depending on the location of the baby seat. The three holes had threads but just make sure the bolts you put aren't too long.
+1Subaman wrote:They are definatly in the roof, complete with thread, the one in the floor you are using is to bolt a tyre in after changing a flat on EFI cars as the standard sized tyre wont fit back under the bonnet where the space saver came from.
You'll need to check, as from memory the child restraint ADR was put into place late in 1978, so it should have them. They should be near the top of the rear tailgate door. They have a special bolt/thread pattern that uses the child restraint anchor bolt (which you can buy from supacrappy). They aren't too hard to fit but if you need help just ask.Rock Ape wrote:Thinking about picking up an 85 touring wagon does this have the 3 holes in the roof for baby seat?
