Diff Cam
PeeJay
Diff Cam
Post by PeeJay » Sat Jun 16, 2007 8:14 pm
Matatak
Post by Matatak » Sat Jun 16, 2007 8:29 pm
so did that help u figure out wt the clunking noise was??
maybe u shuld try a suspension camera aswell
Wagon is no longer....:(
The Subaru Wacky Workshop
-All About the WA Boys :D
theclick
Post by theclick » Sat Jun 16, 2007 8:35 pm
hope that cam was waterproof :D
PeeJay
Post by PeeJay » Sat Jun 16, 2007 9:48 pm
Yep it was!
I think the noise is just backlash in the diff gears, but there seems to be a bit too much movement somewhere. I'll have to check the bush.
Matatak
Post by Matatak » Sat Jun 16, 2007 11:35 pm
so its only making noises when u start moving?
thats the only time ive heard backlash on other cars
Post by steptoe » Sun Jun 17, 2007 11:41 am
not looking at that on dial up for fear of 'problems' but that idea of strapping in a cam in a problem area is one i have been thinking of for years. Good onya for actually doin' it. what sort of camera ? and equiment did you use?
Post by El_Freddo » Sun Jun 17, 2007 6:16 pm
I might give this a go myself... just gotta get the camera now...
Cheers.
PeeJay
Post by PeeJay » Sun Jun 17, 2007 6:58 pm
It makes a "clunk" at the start of acceleration/decelleration.
The camera is a Jaycar QC3449 connected to the external AV in on a dv cam.
http://www.jaycar.com.au/productView.asp?ID=QC3449
We use it at work on the bottom of a tractor plough. I just had it cable tied to the swaybar which is why the fuel tank looks like it's moving.
92 brumby
Post by 92 brumby » Sun Jun 17, 2007 8:29 pm
im having the exact same problem with my brumby at the moment 1 big clunk while braking and again when i take off its only since new engine and gearbox so have you got it down to anything yet i have been under my car 2 weeks in a row now and still no luck
Post by Subafury » Sun Jun 17, 2007 10:18 pm
pity theres no sound to sync the visual with the clunking. but great idea
subarursliberty
Post by subarursliberty » Sun Jun 17, 2007 10:41 pm
Do they move that much?. Seems to be floating around alot.
1992 Subaru Liberty Workshop Manual Complete
http://www.ausubaru.com/forum/showthrea ... #post58409
PeeJay
Post by PeeJay » Mon Jun 18, 2007 5:39 pm
When I used to have an MY wagon I had the same problem in FWD, but in 4WD it was not as bad so I just assumed it was worn gears in the gearbox.
I've only just got the 4WD working in the RX and keep forgetting to see if that makes any difference.
I'll see if I can hook the camera up to something stable and tape it again.
