ej22 into brumby ,help
Is there anyone out there that can help me with my conversion in perth wa,the motor and gearbox is in harness is installed,it's just not idleing right and coughs and splutters a bit. advise and assistance would be greatly appreciated. regards Richard alias Cheffy.
						- tim_81coupe
Well done on the swap Cheffy, good luck with the teething issues.
Matt
									Matt
1989 Subaru WonderBrumby II
conversion help
Hi guys
I'll tell you what we've done just in case there is something we have missed.
-Changed the fuel pumps
-swapped the air filter sensor
-pulled out the harness and connected it up to another motor and it ran fine
-Changed fuel filters
-Changed spark plugs
The fault codes that are coming up on the computer is a fault in all 4 injectorsl I think it's codes 16,17,18,19 from memory, I've got a mate Chris who's been helping me out with it,he's been invaluable but I think where staring to scratch our heads with all the things we've tried.I'm pretty sure Chris said that he'd checked the injectors as well,tomorrow I'm going to pull out all the injectors again and give them another check just to see if there is any crap in them or if ones jamming up which could then upset the fuel pressure going to the other injectors causing the fault codes to come up.
Basically it won't idle when cold,it hesitates a bit when accelerating and throws a couple of bangs out the back(unburnt fuel, or missfires) when it's warm it will idle but not without shaking as if there is a overdone cam in it.
if you guys could add any comment or suggestions it would be greatly appreciated
Regards Cheffy.
Regards Cheffy.
Hi suba mike
Sorry mate yes we also have checked for vacuum hoses,Do you remember me I've spoken to you a couple of times on the radio you put me onto this site some time ago. I think you know Chris, out in Canningvale who's been helping me with the conversion,a bit of a subaru buff isn't he!
Regards Richard , alias Cheffy
- tim_81coupe
- tim_81coupe
- tim_81coupe
My coupe has had nil attention to everything gearbox. I do intend on wiring up the reverse lights, but all I can see the VSS giving me is a 180kmh speed limiter....
There is some reason to hook it up, I'm sure someone more EJ-savvy than me will tell me off for it, but as of yet I've not had a problem there.
82 MY Wagon, EJ20G
87 RX, EJ20G
89 Brumby, EA81
12 BRZ, FA20
						87 RX, EJ20G
89 Brumby, EA81
12 BRZ, FA20
