Subaru Vortex Differences
Johnny T
Post by Johnny T » Wed Jun 28, 2017 6:23 pm
Hi guys
I am about to buy a Series 1 Vortex and just want to know if I can put all my running gear eg: Engine, Gear Box, Diffs etc.. from my current 87.5 Serioes 2 to the new one as the Series 1 is Non Turbo, Auto and FWD.
All I know is that the body is the same and just want to know if the engine and all the bits will just be a straight swap.
If anyone can let me know as soon as possible it would be highly appericated.
Best Regards
Johnny T
Johnny T
88kw of fun waiting to happen
Fitting ...
Post by Bantum » Wed Jun 28, 2017 9:55 pm
From what I've read / seen - All the drive train stuff should fit, but the old FWD series I may not have all the mount points for the 4WD rear end - Only one way to find out - try it & see ... :)
Cheers, Bantum ...
shuffbag
Post by shuffbag » Thu Jun 29, 2017 5:04 am
if its fwd it wont have the captive nuts or holes for the rear mustache bar mounts.
i have done fwd vortex to awd previously and just drilled the holes in the correct location underneath the car. its already marked where the holes need to go.
A slightly bigger hole is needed above (in the boot) to drop a bolt through/hold on to with socket when tightening.
Johnny T
Post by Johnny T » Thu Jun 29, 2017 10:11 am
Thanks for the reply guys. I will be picking up the car this weekend and be posting photos soon :)
Johnny T
Post by El_Freddo » Fri Jun 30, 2017 5:12 pm
Wiring loom may be different too. Use the manifold from the engine that comes with it to run your series 2 block.
You'll need your drive shafts as they'll most likely be the larger spline count units compare to the auto.
Is it green with the brown interior??
Johnny T
Post by Johnny T » Mon Jul 03, 2017 9:54 am
Thanks for the advise Bennie,
I’m going to try this weekend to get my turbo engine from the Series 2 running and then start transferring everything over the weekends with my mechanic :)
and yes it was the Green body with the brown interior and that will be swapped over with my sprayed black interior. I will be taking photos of the build and posting them up, just didn’t get a chance this weekend to get any photos.
Kind Regards
Johnny T
Johnny T
Post by El_Freddo » Mon Jul 03, 2017 9:28 pm
So you're essentially doing a re-shell job.
Swap the wiring loom as well? If you're going to run your turbo engine and all the electricals from your original Vortex I'd recommend this!
Johnny T
Post by Johnny T » Wed Jul 05, 2017 7:30 am
Thanks again Bennie.
If everything goes well this weekend the turbo engine will be running and slowly start the transfer :)
Is it possible to change the front end so I can have the S2 or am I stuck with the S1 front?
Johnny T
Post by El_Freddo » Thu Jul 06, 2017 9:46 am
Front end as in engine crossmember and suspension or front end as in front bar?
Xmember and suspension is all the same and will bolt straight in.
L series suspension will work too ;)
Johnny T
Post by Johnny T » Thu Jul 06, 2017 9:52 am
Thanks again Bennie,
Just the front end as in Front Bumber as I am not the biggest fan of the Series 1 front :)
Johnny T
