Removing Speedo Cable from Gearbox.
Removing gear box having difficulty removing speedo cable from side gearbox. Is it screwed in or is it push in. I dont want damage it .
Clean real good first.
17mm spanner to get it out from memory, turn, rotate spanner, turn, rotate spanner. You'll know what I mean
One of I'm used to turn off centre as it came out. Also be careful as the bit that screws I to the gearbox is plastic. Once the Hex shape is rounded the cable is cactus.
All the best with it
