Snapped bolt for 2" lift kit on brumby
Hi everyone, firstly I'd like to say thanks for being apart of this forum. I've got an insane amount of info on all sorts of topics. If anyone can help me out on this next problem though that would be grand!
I have a 2" lift on my Brumby I've just bought and I've found that one of the rear passenger side 2"lift block is missing. I have the block and I've been to a fastener to got the bolt required. However, it looks as if the previous owner has already had a crack at trying to get the old snapped bolt out of the thread that's apart of the body as there's a snapped drill bit in it. I can't get this puppy out either so I'm hoping that someone may have an idea to get this old bolt out or maybe even if I start doing some welding and maybe make something else up. Also how to I get these rubber bump stops out near rear suspension. Still trying to figure out posting pictures so hopefully I can show the sitcho of what's going down. Thanks in advance for any input!
[ATTACH]4646[/ATTACH]
- image.jpg (13.38 KiB) Viewed 3448 times
And this is the access to where the bolt goes into-
[ATTACH]4649[/ATTACH]
Not sure why but my photos are coming out sideways from my library but if you tilt your head the right way you can see it's completely sealed. Once I rectify this problem, should I strengthen this rig by welding steel between the two blocks?
- image.jpg (13.1 KiB) Viewed 3449 times
