How does shifting w out the clutch work?
Hey guys,
Was driving home from work the other day. Happened to be in 4th gear, had my hand on the lever and popped it outta gear without using the clutch, was doing maybe 60km/h, and was off the gas.
Is its something to do with the engine RPM matching the gears rotation speed?
I've heard of shifling both up and down without usining the clutch...how does this work?
I cannot seem to get it into a gear though have not tried too hard as i'm scared of doing some damage.
Smokey.
Smokey.
- Suby Wan Kenobi
- tim_81coupe
AHAHHA you truely scare me Tim.
Dave
Dave
- tim_81coupe
Yeah it seems hard at first but once you've got used to matching revs to gears it becomes pretty easy.
You will crash gears if you try it in a car with different gear ratios! Also there are some boxes that simply don't like it (tremec T5 springs to mind... ugh).
You can actually drive fairly smoothly after a while without the clutch but the time it takes to shift gears is longer.
82 MY Wagon, EJ20G
87 RX, EJ20G
89 Brumby, EA81
12 BRZ, FA20
87 RX, EJ20G
89 Brumby, EA81
12 BRZ, FA20
- tim_81coupe
that clutch was only replaced late last year (or was it early this year?)
Why the need for clutchless shifting?
You shouldn't have you're hand resting on the shifter whilst driving. It causes premature wear on the synchros.
As for the gear popping out? A standard trait unfortunately for lifted subarus, due to incorrect lengths with shifter linkages. You may need to alter your driving technique to help prevent this from occurring.
I wouldn't do clutchless shifts on a subaru, with a reputation for weak gearboxes and synchromesh. just not worth a gearbox change just to pick up a skill you'd virtually hardly use IMHO.
1998 Subaru Legacy GTB
I don't know about poles... all i know is just remember that its the brake pedal your using the left on... first few times i left braked it was a clutch pedal action i used :s At least i know my ancors work well...mattims wrote:and when your using left for braking .. remember to watch out for poles as my L series would tell you, they leave a nasty dent.
Thanks for the replies guys. That makes it a little clearer for that day when I just might need to learn in a hurry...
Smokey.
I didn't say which car I was in did I.... Was in my liberty, unlifted w origional clutch and 180k on the clock. Thanks for the heads up thoughsmoov wrote: As for the gear popping out? A standard trait unfortunately for lifted subarus, due to incorrect lengths with shifter linkages. You may need to alter your driving technique to help prevent this from occurring..
Smokey.
Its a good skill to develop. You never know when you might have to drive when you've broken a clutch cable.
I snapped one in Moree on Dec 23 (Sat) & had to drive to Brisbane because I was flying overseas on boxing day. About 500kms.
Once upto speed was fine, but had to turn car off at lights & put back into 1st, then start car.
I looked like a learner:rolleyes:
Current rides:
JDM GTII Touring wagon
Previous rides:
96 Toyota Caldina wagon
:???:Previous rides:
