well, might actually need some help for jimbo kneebone (pillarless jim) to be able to sign in too....
jim is having much trouble with the L Sedans fabric hoodlining falling about messing up his hair.
Gravity is not on his side. I would suggest he drain fluids from car and mak a rotissarie for sedan to solve that problem so his spray glue works.
Any tips while he sorts his posting problem ?
roof lining fix HELP wanted
- Silverbullet
Could be another difference between touring wagons/higher optioned cars and the normal low roof wagons and povvo pack sedans. My Dad's L has a moulded vinyl with foam backing roof lining, the touring wagon I had briefly had cloth, held in place in a few spots by thumb tacks
You should be able to remove the entire foam roof lining section from the car, I know you can with the MY's. Remove all the retaining trim pieces around the edges, remove the light and it should pop out I think. Alot easier to then strip off the old fabric and spray glue on some new stuff in whatever colour you want.
