Shocks!!!!
Shocks!!!!
Checked the threads, could not identify a recommendation for aftermarket shocks for a Brumby (1988). Specifically chasing rear shocks BTW.
I may have missed it but would like to know what members think is the best bang for buck?, happy to go with originals if that's the general concensus.
As usual imput appreciated
cheers
Ray
cheers
Ray
- Rodeo4jake
- TOONGA
here you go
http://www.ebay.com.au/sch/i.html?_saca ... er&_sop=15
from 58 dollars for 1, to 105 dollars for a pair
Brumby shocks
Got a set for my 89 Brumby from Pedars. About $150????? a set, I think.
Find out if the ones from subaru are gas or oil filled. My bet is that they'll be oil filled. The others will be gas.
Oil is preferred for offroading, gas gives good ride on-road apparently but once they start to leak that's the end of them where as the oil filled units will continue to work until they loose all their oil, this can take quite some time to occur!
Start cleaning up the area behind the captive nuts and add some penetrene or WD40. Mud/road grime sits up there and those bolts are crazy to undo. I'm still working on one at the moment - third go next time I'm at it
- Backyard_Brumby
It would depend on how long you're keeping the car and what you budget is. IMO you can not get better than the original (oil filled) shockies. These will last 3 to 4 times longer than the gas ones. So even know you pay less for the gas ones, they don't last as long but the gas ones ride better.Wooster wrote:INterestingly , shocks are available via ebay for about $110 a pair, originals from Subaru for $215 a pair, Bursons $260 a pair. I think I'll keep sniffing
Very true Bennie. The gas struts are guaranteed for 50,000kms but some might last closer to 100,000kms. I have seen some original struts in cars well past the 300,000kms mark.El_Freddo wrote:Find out if the ones from subaru are gas or oil filled. My bet is that they'll be oil filled. The others will be gas.
Lift kits, if they are the complete "body" lift kit, make no difference to the suspension setup, as the only move the body up. All the suspension parts stay in the original position. If you go the "siuspension" lift kit, then this puts extra stress on suspension components. Either way, you should always use lift blocks on the bump stops to stop the strut from failure.Backyard_Brumby wrote:To take this discussion further, with a 2" lift kit fitted, do the standard rear shocks work OK or should there be a block at the top to compensate for the extra height? Thanks.
- Backyard_Brumby
Thanks RSR, my "body" lift kit came with all the lifting blocks for the body and front struts but nothing for the rear shocks. As the original shocks are now operating in a more extended position, I'm thinking that I have to find some blocks to fit at the top of the rear shocks or source some shocks that are longer so that they will operate in the mid range of movement - if anyone has any experience with this, please let me know.
[SIGPIC][/SIGPIC]James
Yes the lift kit should have brackets at the top the same length as what ever kit you have fitted, the best option is rather than make an extension for the shocks, you make a new top shock mout up to suit eye to eye style shocks and then you can fit longer shocks in the from the rear of a land cruiser or something, really opens the doors up to your choice and style of shock then and also benifts your rear wheel travel.
Yeah James, just as Grant has said, you should have extension pieces (same height as the rest of the kit) on top of the rear shocks, if you are using the standard rear shockies. This will stop the shockies getting damaged at full stretch.
I have seen other shocks being used (going off memory here), somone was using HQ Holden rear air shocks, that just require a modified top bracket and it worked really well. Jules (TOONGA) has modified a set of Honda struts in the back of his Brumby (which has a 2" lift kit) and they are adjustable coil-over style ones. Have a search for his thread.
