XV test drive
Dikman
Post by Dikman » Fri May 25, 2012 8:13 pm
Picked it up a couple of days ago, but haven't had much of a chance to drive it (daughter and two kiddies now staying with us, so things are somewhat chaotic!).
Anyhow, the drive home was going to be the telling point. I live up in the hills, out of Adelaide. The freeway from the city up is 10 kms - 100 kms/hr - of constant gradient (17% I think), and it's a killer for automatics. If you don't lock them in a lower gear they hunt up and down. The 4 speed in the Forester hates it.
The CVT is brilliant! Plonk it in D and away it goes, no hunting, no shifting, no lurching between gears! Whether it's going uphill, downhill or just around town. Luvverly! Pickup seemed slightly better than the Forrie, a bit quicker response from the throttle (electric throttle, I suppose?).
The electric steering feels a bit different to the hydraulic, slightly touchier, maybe, but it's early days yet to judge it. It certainly works well, but just feels different.
Brakes work well enough, of course, but they seem strangely "dead" compared to the Forrie (admittedly, I've just fitted new pads to it, so they probably have different material to the XV). Nevertheless, they don't seem to have the initial bite that the Forrie has.
Suspension feels a bit firm, but should soften a little as it loosens up.
In general, it's a very nice car and feels very classy!:D
Downside? The internal storage pockets, strangely enough. The door pockets are smaller than the Forrie (can't even fit a street directory in) - although each one has a cupholder in it :roll:, and the glovebox is smaller. The Forrie has a strap on the spare wheel cover that lets you clip the cover up out of the way - the XV has nothing like that, you lift up the cover and have to juggle holding it up while fiddling around with the spare wheel. Only a little thing, perhaps, but it's the little things that tend to annoy me.
Speaking of which, I bought the Subaru Cross Bars for the roof rails (I've always had crossbars on all my cars, very useful things). I decided on the genuine parts, figuring they would be designed specifically for the car. These are Thule bars, so pretty good quality. Well, after stuffing around with them for a couple of hours I came to the conclusion that the clamps were the wrong ones, as no way would the inner clamp sit flat to the side of the rail as I tightened it up. I took them back and spoke to the spares guy, who confirmed it was the correct part number. Hmmm. He agreed that it didn't look right, but said they'd fitted about 30 of these and no-one had said anything before. I then looked at a display Forester that had the same rail/bar setup and yep, the inner clamp stuck out at a funny angle. He said he will pass it on to Head Office, as he agreed that, considering Subaru genuine accessories are supposed to be designed to fit the particular model, it didn't look the best. I said in my opinion it looked cheap and nasty!
Be interesting to see what happens.
Tweety
Post by Tweety » Fri May 25, 2012 8:49 pm
Congrats Dikman
Re: suspension firmness.
I had a brand new VW Tiguan. Being fully optioned it had a rare set of mag wheels (that didnt look much different to the standard mags) and these came with lower profile tyres.
I then noticed on my tyre calculator (on google) that the circumference was less than the standard tyre and furthermore the speedo read less than real speed.
The biggest issue though was the rough ride mainly on bitumen bumpy roads.
So when the time came to renew my tyres I returnd to the tyre calculator to find a tyre that gave me the required 6% increase in circumference, that would fit under the guards and the spare would fit in the full size well.
It was much better all round, the speedo spot on, the tyres were cheaper and my dentures stopped rattling..;)
Post by El_Freddo » Sat May 26, 2012 12:28 am
thunder039 wrote:do you work at hotham bennie? you seem to spend alot of time there...
I did last year and the year before, but unfortunately I am not this year, trying to get a full time teaching job. But I've been lucky enough to hang out up here while my better half trains some staff for this season. It's worked out very well so far.
Dikman wrote: He said he will pass it on to Head Office, as he agreed that, considering Subaru genuine accessories are supposed to be designed to fit the particular model, it didn't look the best. I said in my opinion it looked cheap and nasty!
I'll be keen to hear what they have to say. I'm hoping it's positive!
Dikman
Post by Dikman » Sat May 26, 2012 1:55 pm
Couple of other things I thought about. DiscoP would absolutely hate it! The electronics inside are a technological junkies dream :lol:! Suits me, though, I have lots of settings to play with! Amongst other things you can set reminders for the next service (based on time and/or distance) - oil, filter, next service itself and tyres (!). This last one has me a bit perplexed. However, the beauty of this system is that it's completely at the control of the owner, you can set whatever you like or turn it off completely. Which is good, I hate those things where you have to go to the dealer to have them reset.
Engine oil. It uses 0-W20!!! Jarvis have a Subaru-trained "Master Technician", and I got to talk to him abut a couple of things. When he told me about the oil, I said I didn't recall seeing that grade anywhere. As I like to change my oil a bit more often than the recommendation, particularly when new, he said if I bring in a container he will provide some (they use bulk drums, of course). He also mentioned that these engines have extremely hard rings, and can take a while to bed in properly.
There are two handbooks with it, which I'm still wading through!!
Brumby Kid
Post by Brumby Kid » Sat May 26, 2012 2:40 pm
Went to Jarvis today to pickup my head studs. Han a look at one of about 10 xv's.
Not bad but one major complaint. Where is the boot?
It is tiny!
Cheers Cam
Dads Car: 02 Impreza WRX STi
Dikman
Post by Dikman » Sat May 26, 2012 7:55 pm
Yep, compared to the Forrie there ain't much there! Still, it's big enough for my wife to put in the shopping, but it's going to be hard to get much firewood in there :roll:.
Dikman
Post by Dikman » Sat Jun 02, 2012 5:29 pm
Regarding the roof bars, Subaru are still trying to find the right guy to talk to, but in the meantime I contacted Thule Aust. about my concerns. They said yes, that is the right kit and that's how it fits. They said it's perfectly safe (!) the way it clamps up, and apparently the fact that it looks like something copied by a Chinese factory (who didn't quite get it right) doesn't matter!!
I've attached a photo of it, you decide whether I'm being too picky, but I find it disappointing that a company like Thule considers it acceptable to use a clamp that is obviously not designed for that particular rail.
They also state that the clamps should be tightened to 4Nm, but don't provide a suitable socket to fit to the spline-headed bolt that they use. Maybe you guys are better than me, but I'm not real good at judging a specific torque by hand (that's why I have torque wrenches!).
Personally, I wouldn't advise buying the Thule bars for the XV, as they're obviously not designed specifically for the roof rails.
I'm thinking of writing to the Swedish factory and complaining, I'm just not impressed.
thunder039
Post by thunder039 » Sat Jun 02, 2012 7:18 pm
my roof bars dont fit perfectly either but they are functional and i carry a fair bit of weight on them aswell,
but mine do fit better then the picture you put up
2004 subaru forester -gone
1989 subaru brumby- sold!
2008 zook jimny -sold!
taza
Post by taza » Sat Jun 02, 2012 7:34 pm
Whats a crap fit!
My Rhino Racks fit perfect on my Foresters roof rails.
thunder039
Post by thunder039 » Sat Jun 02, 2012 7:42 pm
mine are almost on the 04 forester dont have them for the 99
olddog642
Post by olddog642 » Sat Jun 02, 2012 10:49 pm
The way those bar brackets fit up looks like (*&^^) in my opinion they look as though if you hit a jumpup at speed the whole lot will come adrift.:confused:
username
Post by username » Sun Jun 03, 2012 12:04 am
El_Freddo wrote: I did last year and the year before
At hot doggies?
sjm69
Post by sjm69 » Sun Jun 03, 2012 6:44 am
I'm thinking of writing to the Swedish factory and complaining, I'm just not impressed.[/QUOTE]
Shit I would not like to go over a speed hump with those on my roof with weight on them to me they don't look attached enough and not safe at all
Dikman
Post by Dikman » Sun Jun 03, 2012 8:55 am
I don't think they will come adrift too easily, as the outer clamp (which is a "universal" clamp, again not designed specifically for the car), is a reasonably close fit and extends under the bottom of the rail. What I don't like is that the clamping force on the inner rail is only along the top inner edge, not flat along the whole inside rail surface - which the clamp is clearly designed to do.
At least I know it's not just me who is unimpressed! These, btw, are the same ones fitted to new Foresters (and look even worse), whereas my 2004 ROLA bars are a perfect fit on that car.
olddog642
Post by olddog642 » Sun Jun 03, 2012 10:40 am
[quote="Dikman"]I don't think they will come adrift too easily, as the outer clamp (which is a "universal" clamp, again not designed specifically for the car), is a reasonably close fit and extends under the bottom of the rail.
:sad:Well if the bottom lip is secured under the rail it may be safe but I still don't trust it, the whole set up with the inside top clamp looks like something the cat dragged in only worse.
The whole setup is not aesthetically pleasing plus not at all in keeping with the overall look of the vehicle.
Hylton:evil::twisted:
Dikman
Post by Dikman » Sun Jun 03, 2012 11:49 am
olddog642 wrote: The whole setup is not aesthetically pleasing plus not at all in keeping with the overall look of the vehicle.
That is exactly what I told the Subaru parts chap. I just couldn't believe that Subaru would consider something like this acceptable!
Grant_Adelaide
Post by Grant_Adelaide » Sun Jun 03, 2012 5:27 pm
Hi All,
I ended up buying the Prorack Whispbars, fit perfectly and are the quietest on the market.
http://www.whispbar.com.au/findmycar
Check out the comparison video for wind noise and there are close up photos of the fit on the roof rails... and to top it off they were considerably cheaper from Supercheap or BCF here in Aus.
olddog642
Post by olddog642 » Sun Jun 03, 2012 7:33 pm
Grant_Adelaide wrote:Hi All,
Now that is more like it they do add to the vehiclé not subtrack from its looks.
:D
Dikman
Post by Dikman » Sun Jun 03, 2012 8:36 pm
Agreed. They look pretty neat. Which version did you get?
In the meantime, I've sent off an email to Thule Sweden (cc to Thule Aust) voicing my concerns about what I consider to be poor design and fit, amongst other things. (For instance, they specify a tightening torque of 4 Nm, but they use a non-standard fastener - a spline-headed bolt - and do not provide any adaptor to fit a torque wrench. There is nothing in my pile of tools that comes even close to fitting it! So how am I supposed to know if it's tight enough? Or too tight?).
I'm not expecting a positive outcome :rolleyes:.
olddog642
Post by olddog642 » Sun Jun 03, 2012 8:48 pm
Dikman wrote:Agreed. They look pretty neat. Which version did you get?
In the meantime, I've sent off an email to Thule Sweden (cc to Thule Aust) enough? Or too tight?).
Don't hold your breath remember that the swedish manufacturers think that they are doing you a great service just by letting you purchase their products .
Hylton;):evil::twisted:
