2010 Diesel Drivetrain shudder
- Not Happy Jan !!
- StrontiumSteel
It's baaaa-ack!
Well, our first 2 days over 25C in a row and it's back: I've had my fist noticeable regens in months. They seemingly disappeared over our Canberra winter, nothing in the drivability or the instamatic-fuel-econ-readout to indicate any.
Today and yesterday (well Sat and Sun, not early Mon am driving generated power saps, plus muted (but noticeable) clunking/thunking as something cut in and out depending on the throttle and revs. It feels a little like a worn bush under accel/decel, but worn bushes don't sap your power or fuel economy.
It was annoying enough for me to keep provoking it by cycling the throttle, annoying myself even further. To go with it is the power sap indicative of some major engine map/tune/setup change.
The only other option I can think of is that it's the air-con cutting in and out depending on the throttle position, but A/C doesn't sap THAT much power (or fuel).
Also has anyone noticed that during these periods throttle response may be OK upto, say, 1/2 throttle but really dies- as in decreases performance- above that? It's almost like an old mistuned carby engine.
 driving generated power saps, plus muted (but noticeable) clunking/thunking as something cut in and out depending on the throttle and revs. It feels a little like a worn bush under accel/decel, but worn bushes don't sap your power or fuel economy.It was annoying enough for me to keep provoking it by cycling the throttle, annoying myself even further. To go with it is the power sap indicative of some major engine map/tune/setup change.
Patrick
Ex- 2010 Forester Diesel
- discopotato03
I think the way to get the manufacturer to try harder is to advertise everywhere that these Subaru "oilers" are having all sorts of driveability issues and prospective buyers need to know it .
The net is a great way to get info out there globally . Make it known on every site everywhere that these things have issues and if customers don't want them to consider looking elsewhere .
Nothing spooks a manufacturer more than sales resistance because it can break them very easily .
I feel sorry for Zoob in a way because these reactors have been forced upon them and they are obviously struggling to meet emissions targets affordably .
I look at cars a bit differently to many people and unless I suddenly became filthy filthy rich I wouldn't own a brand new one , by choice not financial constraints .
Because mechanics have been friends of mine for a long time I look harder at the serviceability of cars and to me a current model bastardised electronic controlled diesel is a nightmare . IMO diesels were marketed to be a soild reliable durable workhorse and made lots of torque without many revs .
Simple and easy to service at home ie oil/filters/the odd bleed if you ran it out of fuel . Sounds a bit like the original standard Brumby concept doesn't it ?
I reckon the last thing a cocky on the farms going to want is a a diesel car thats run by black boxes that has to be driven like a petrol car so it doesn't cough and fart and jerk around . He hasn't got time to be back and forth to the dealership so the old Tojo tray/ute/troopy will live longer and he'll be happy to put the missus in it cause they know its going to get them where they want to go .
To me a Subaru diesel is like a Prius , pretending to be green while catering to the Browns . I'd rather use more juice and have less dramas in life , oh and unlike the cow in the diesel Terrotory ad I don't do social networking nor feel the need to do a thousand kay 50 "friends" fest on a single tank of fuel .
A .
A .
- Brumby Kid
I havn't read the whole thread and dont know much detail, but it sounds like the engine might be detonating, or pinging. This used to happed in my dads old old lancer up a long hill. Thoughts?
Cheers Cam
									Cheers Cam
- Brumby Kid
Yep, i read a bit more, sounds like pre detonation. What happened to dad is your going up a hill in say 3rd or 4th. You then lose speed, and it starts to pre detonate (ping). The only solution is to change down and hope you can get your revs up high enough. A number of posts on here say they have the same circumstances as what I am discribing. Have you totally ruled this out?
I am now suffering similiar issues with my diesel, and i've had a mild shudder occur a couple of times on the highway in the last 3000k's. Ever since i had the 37500km service done about a month ago the engine has run differently. You can just tell the computer is busy doing stuff while you are driving.pitrack_1 wrote:Well, our first 2 days over 25C in a row and it's back: I've had my fist noticeable regens in months. They seemingly disappeared over our Canberra winter, nothing in the drivability or the instamatic-fuel-econ-readout to indicate any.
Today and yesterday (well Sat and Sun, not early Mon amdriving generated power saps, plus muted (but noticeable) clunking/thunking as something cut in and out depending on the throttle and revs. It feels a little like a worn bush under accel/decel, but worn bushes don't sap your power or fuel economy.
Between the 25k and 37.5k services it was a joy to drive. It was responsive, punchy and had terrific economy. Now it drives like a pig. At first start up in the morning it stutters and feels like it is starving of fuel when at light throttle loads. It needs more throttle input to get moving at low speeds than it used to. It suffers from the power sapping lag regardless if you are on boost or not. The economy has also gotten slightly worse. I asked the service guys what had been done and they said "we've done nothing, just reset the oil dilution". If the ECU has t re-learn every time after a service, well that is just crap.
I mostly agree mate. What's the point of changing the oil in these if you can't reset the oil-dilution ratio yourself? (Maybe there is a way, i'm not sure.)discopotato03 wrote: Because mechanics have been friends of mine for a long time I look harder at the serviceability of cars and to me a current model bastardised electronic controlled diesel is a nightmare . IMO diesels were marketed to be a soild reliable durable workhorse and made lots of torque without many revs .
A .
These new-school diesels do not have the torque many people associate with a diesel. Off idle they are pathetic. I need a run-up to get up my steep driveway and pretty much ride-the-clutch all the way up. My old diesel landcruiser won't win any land-speed records, but it idles up it easily. These engines need to be on-boost to be any good. Sadly i don't feel that "solid-reliable workhorse" can be used to describe these new electronic diesels. I'd probably call them "fragile", fuel-efficiant....sure, but definitely fragile. They are not the sort of car i would buy second-hand, not knowing the history.
Dan
07/2010 Forester 2.0D Premium
1979 Toyota BJ40 Landcruiser (Old-school diesel! )
)- discopotato03
I occassionally drive a couple of late Isuzu trucks with these electronically controlled and reactor equipt exhausts . For a turbo diesel they are not terribly torquey well at least until they get some boost into them .Falco80 wrote:I am now suffering similiar issues with my diesel, and i've had a mild shudder occur a couple of times on the highway in the last 3000k's. Ever since i had the 37500km service done about a month ago the engine has run differently. You can just tell the computer is busy doing stuff while you are driving.
Nope , if I wanted a real diesel I'd buy an older one and if necessary rebuild it . To me the whole idea of the things was to be reliable stump pullers without carburettors or EFI or even ignition systems . If you "strain" all the low end torque out of a diesel then its a bloody hopeless failure in my book . Adding electronics and problematic tuning throws away the last vestiges of practicality so I have to say "why would you bother ?" .
If I really wanted a late Sube , never going to happen either , it would be a petrol fired one knowing that its a whole lot less grief even if it does use a bit more juice . If you got one a couple of years old then you save a fortune and can afford to pay for the petrol .
Diesel Zoob , not on your life cheers A .
Yesterday I had something different. A White cloud appeared behind me when the shudders occurred. This morning I went to the Subaru dealership and their main mechanic (the one to witness the shudders) told me that it was a good thing, because the engine did a regeneration. He told me that FHI told them that the shudders problem is caused by the exhaust system being clogged and he is now doing force regeneration, which should clear the problem.
I hope it will.
						I hope it will.
How does the exhaust get clogged?! Apart from the old spud in the tailpipe gag that is loltasla wrote:Yesterday I had something different. A White cloud appeared behind me when the shudders occurred. This morning I went to the Subaru dealership and their main mechanic (the one to witness the shudders) told me that it was a good thing, because the engine did a regeneration. He told me that FHI told them that the shudders problem is caused by the exhaust system being clogged and he is now doing force regeneration, which should clear the problem.
I hope it will.
Good luck, hope it fixes it
White Cloud , sounds like a native American  white is lean or misfire in a Diesel (or you got some petrol in the mix). I understand a regen to be a richening of the mix so it generates heat - wouldn't that be black smoke?
Can just imagine what will happen to the exhausts on these once warranty is out
 white is lean or misfire in a Diesel (or you got some petrol in the mix). I understand a regen to be a richening of the mix so it generates heat - wouldn't that be black smoke?Can just imagine what will happen to the exhausts on these once warranty is out
White 'smoke' could be:steptoe wrote:White Cloud , sounds like a native Americanwhite is lean or misfire in a Diesel (or you got some petrol in the mix). I understand a regen to be a richening of the mix so it generates heat - wouldn't that be black smoke?
a) Water condensation. Max Temp yesterday (27th Oct) in the Hague was somewhere mid teens C (~60F) with ~70-85% RH. So the white cloud could have been condensation. It happens in Canberra in winter even with warmed-up vehicles.
b) Water in the exhaust, e.g. through an engine problem such as a cracked cylinder head or blown head gasket.
c) Fuel (diesel) in the exhaust system. This tallies with the DPF regen theory.
Black smoke generally indicates incomplete combustion and is what the DPF is meant to trap anyway...
Some generalised info at http://www.dieselsmoke.com.au/
So can I. And someone priced DPF replacement elsewhere at (I think) ~3000 Euro. ANd they will be consumable items replaceable after a few years- the problem is they will regen and remove the soot, but cannot remove the small amounts of contaminant ash that will slowly build up over time. So eventually the DPF may become clogged with non-regeneratable ash and require replacement.steptoe wrote: Can just imagine what will happen to the exhausts on these once warranty is out
My hope is DPFs will be like catalytic converters quickly became- effective whole-of-life components, so they won't clog until after the vehicle is reasonably expected to be dead anyway. And/or they will attain a reasonable price point for replacement as production gears up.
Otherwise I'm outta the Forester diesel and into another vehicle! The new generation petrols such as the Mazda Sky-activ and VW 1.4l twin-charged petrol engines seem to combine the flexible performance of petrol with the economy and torquiness of diesels. I'll wait and see though for some long-term reliability given the complexity of the engines. The Oz sky-activ has been derated due to Oz's (derated) standard ULP (91RON). And there's apparently a sky-activ diesel on the way too. Just perhaps these petrols could (ahem) drive the diesels back away from the passenger vehicle market again esp. given diesel is more expensive than petrol.
Patrick
