Pounds - metric
- Outback bloke
Pounds - metric
How does 1027lbs of torque convert to metric?
						- Outback bloke
http://www.unitconversion.org/unit_converter/force.html
1 pound-force = 0.45359237 kilogram-force is what I have found.
- Ben
Brett,
torque is the measurment of force applied at a distance measured from the application point.
1027 pounds of torque is not a real measurement, it should be over a length - usually feet for pounds and metres for kilograms.
1 pound = .454kg
1 pound at one foot distance from the fulcrum (lever point) is .454kg at one foot, but is .454/3.281 (feet per metre) = 0.138 kilograms at one metre
hence to translate 1027 lb-ft is equal to 141.7 kg-m
Kilogram is a unit of weight as a mass applies on earthsubject to gravity. All objects accelerate towards the centre of the earth at 9.81m per second. If you don't account for the acceleration of gravity as it applies to a mass on a body then you multiply the mass by the value of acceleration - hence 1kg is 9.81 newtons. Therefore, to convert 1 kg-m to n-m (nm) you just multiply it by 9.81 and so 1027 lb-ft = 141.7 kg-m = 1390 nm
Interesingly, if you put a 1 metre bar (on a nut say) and then hang your full body weight off it (I am 80kg so will work on that) I am applying 80kgm force to that nut - that is 785nm torque. The engine in my wagon can develop only 181nm torque maximum. In theory, a weight of 19kg hung off a 1 metre bar is sufficient to stop the engine dead. Unfortunately that doesn't take into account momentum, inertia, etc, etc and is actually why we have flywheels - that's just to keep the bloody thing running!!!
explain things better?
1 pound = .454kg
- Outback bloke
I thought that torque is measured over distance myself until I was at the dyno today. I was told that "the car has 850 pounds of torque and that is not foot pounds". I was then told that due to the gearing of the big tyres that it would be about 1027 pounds on standard rubber.
That kind of confused me but I thought it must have been some different way that things are measured on dynos.
- Ben
I don't know the torque relationship as it acts on a dyno and 850 ft-lb is quite possible, especially in lower gears (was it a 3rd gear run?)BYB-01 wrote:I was told that "the car has 850 pounds of torque and that is not foot pounds". I was then told that due to the gearing of the big tyres that it would be about 1027 pounds on standard rubber.
Maybe he was talking foot-yards??? :P
- Outback bloke
- Sti_Brumby
