5 speed into brumby
jess 94
5 speed into brumby
Post by jess 94 » Sun Feb 13, 2011 7:54 pm
Hi new to this but can anyone tell me if a L series 5 speed will go into a brumby with out to many mods.Cheers
Post by El_Freddo » Sun Feb 13, 2011 8:00 pm
Yes it can. I've not done it but have all the bits to have a go at it.
You'll need a new crossmember and to mount the centre bearing of the L series tail shaft. You'll also have to do something with the clutch, I'm not sure about this. And space out the starter motor by a couple of mm - a couple of washers sorts out this one nice and easy.
Do a search, loads of info out there to do it!
Post by TOONGA » Sun Feb 13, 2011 8:05 pm
welcome to the board jess 94, if you look at this thread you will find 99.99% of the information you need to make the conversion
showthread.php?t=11821
