brumby front wheel hubs
- Creamfeeder
hi guys, just wondering how hard it is to source front wheel hubs for brumbies. will any hub form older 4wd subies fit? there is the possibility that mine might be shot so i thought Id try and source one now, having the front pass bearing replaced soon as it IS shot and was going to have the mech have a look at the hub while hes at it.
Any from the 1980 to 1984 M.Y. wagons, sedans or coupes will also fit but really only need to be replaced when the spline is worn out. Make sure the taper washer has smooth edges (no lips) when reinstalling.. also make sure the CV nut is done up as tight as you can get it.
