f*&ked clutch or just clutch cable
- Creamfeeder
Hi guys, I m having issues with the brumby. the clutch doesnt disengage when i push down the clutch pedal. I have noticed that recently it has been taking more action on the pedal to get it to disengage, so I have been tightening the clutch cable adjustment screws to compensate. Now however, it just doesnt disengage at all, and I have to use more force to get the pedal to the floor. Is this a clutch cable issue, or is my clutch just had it? If it is a cable have any of you guys got one to sell me or some info as to where to get one? Being carless sucks balls!!!:mad:
						- Creamfeeder
- gtcompletepower
- gtcompletepower
Are you able to stall in 4th gear? If u can then the clutch is ok, problem will be somewhere, I would start looking at clutch cable, Pedel box, clutch fork.. Is there any weird noises? (ie grinding or squel?)
cheers
									cheers
- Creamfeeder
- Creamfeeder
- Battlewagon
- sven '2'
Very common - try here? vbclassified.php?do=ad&id=880Creamfeeder wrote:thanks for all the info, guys. will look into it soon. How easy is it to get e clutch box, none of the spares stores here have ANY brumby or old subie parts. Very annoying?
Better to weld yours adding a bit of flatbar for good measure
Sven
Hey matey, the reason the gears are crunching is because the pedal box is flexing, so when the clutch is pressed the box bends and the clutch plate doesnt even move. Think of it as trying to change gears without even using the clutch. I found that out the hard way one night on a club run. I took mine out and just got some guys to weld it up for me.
Yep.. pedal box and cable are most likely very worn for many years of use. I'd start with these before pulling the clutch out, a lot less work
We just this past week replaced the Clutch fork on our Vortex for exactly the same reason. Cable was adjusted several times until nothing left. The fork had suffered severe metal fatigue and was about to disintegrate.
Get a torch and look down the hole in the bell housing while someone else presses the clutch. You will see if it wants to split and climb over the ball pivot.
Gearbox out to replace I am afraid.
Dave Hill
MY13 Outback - The new blue one.
MY99 Outback - As it's maker intended - but with a fresher engine now.
1994 RS Turbo - Not quite so stock! And freshly repainted now
And then there's the family Vortex - rebuilt, updated and now unregistered and gathering dust in the shed.
I have a very good secondhand one if you like?
