Thermo fans help.
- little_red_L
Thermo fans help.
Hey all, as a result of my lift kit, the engine driven fan hangs about 1.5" under the level of the front bar. And therfore isn't achieving optimum cooling capacity.
So i have bought a 10" davies craig fan, ($75, cheers to ebay;)) and i was wondering if the factory wiring set-up to the A/C fan would be tough enough to withstand the extra load if i was to wire the new one into it. or would it overload and catch on fire?
Anyone done this? pls help.
Red 1990 L series sportswagon: sports muffler, 4" lift, pod filter, powersteer conversion, pug 14's and a coupla stickers. with 27"s on their way. Everything else? Standard. For now....
						look at the load of the original fans, they might be exactly the same
									if im needed for anything [email protected] and ill try and get back to you.
pickstock racing fabrication
pickstock racing photography
GETDIRTYCLOTHING
GETDIRTYCLOTHING
- twilightprotege
yeah but what rating are yours twighlight??
the wiring might not take it..
ok so yeah it probably will but i just want you to check
GETDIRTYCLOTHING
GETDIRTYCLOTHING
- twilightprotege
- little_red_L
so, i got the kit and it had a mini-loom with a relay and a fuse and the likes. so i connected the appropriate wires from the fan to the relay (black n blue), then the main power to the relay i scotch-locked into the power supply to the A/C fan (red), thinking that it could only turn on when the A/C fan was, but i got nothing. i checked the earth and fuse, they were fine. The fifth wire from the relay (green) was intended for the A/C clutch, i supplied it power and the fan works, but 100% of the time.
Anyone got any ideas? im stuck.
