Thermo fans help.
little_red_L
Thermo fans help.
Post by little_red_L » Thu Apr 15, 2010 8:20 pm
Hey all, as a result of my lift kit, the engine driven fan hangs about 1.5" under the level of the front bar. And therfore isn't achieving optimum cooling capacity.
So i have bought a 10" davies craig fan, ($75, cheers to ebay;)) and i was wondering if the factory wiring set-up to the A/C fan would be tough enough to withstand the extra load if i was to wire the new one into it. or would it overload and catch on fire?
Anyone done this? pls help.
Red 1990 L series sportswagon: sports muffler, 4" lift, pod filter, powersteer conversion, pug 14's and a coupla stickers. with 27"s on their way. Everything else? Standard. For now....
spike
Post by spike » Thu Apr 15, 2010 8:41 pm
look at the load of the original fans, they might be exactly the same
twilightprotege
Post by twilightprotege » Sat Apr 17, 2010 7:06 am
mine is wired like that - perfectly fine
spike
Post by spike » Sat Apr 17, 2010 8:41 am
yeah but what rating are yours twighlight??
the wiring might not take it..
ok so yeah it probably will but i just want you to check
twilightprotege
Post by twilightprotege » Sat Apr 17, 2010 9:14 am
1 is the stocko air cond fan, the other is a 10" ebay cheapie
little_red_L
Post by little_red_L » Sun Apr 18, 2010 6:15 pm
so, i got the kit and it had a mini-loom with a relay and a fuse and the likes. so i connected the appropriate wires from the fan to the relay (black n blue), then the main power to the relay i scotch-locked into the power supply to the A/C fan (red), thinking that it could only turn on when the A/C fan was, but i got nothing. i checked the earth and fuse, they were fine. The fifth wire from the relay (green) was intended for the A/C clutch, i supplied it power and the fan works, but 100% of the time.
Anyone got any ideas? im stuck.
