what do you think is max. psi for EA82 Turbo?
Kralle
Post by Kralle » Mon Jan 11, 2010 3:59 am
Hello,
what is the max. boost pressure for a EA82T engine till his headgasket blows, i mean only the engine, not the turbocharger.
Post by Gannon » Mon Jan 11, 2010 5:12 am
Depend on what other mods you have.
If its a stock standard EA82T, i wouldn't go over 9psi
If you have an intercooler, larger exhaust, run premium fuel, you might get away with 12-15psi
Just remember that the higher you push it, the higher the chance you will blow it up
Kralle
Post by Kralle » Mon Jan 11, 2010 5:28 am
im looking forward to mount an intercooler
do you mean the larger exhaust after the turbocharger or befor? because i think after the turbo, the exhaust is a little bit to small.
I run fuel with 98 ROZ
Post by steptoe » Mon Jan 11, 2010 7:49 am
uh oh, another power demon. The more boost the less life
Turbone
Post by Turbone » Tue Jan 12, 2010 4:30 pm
I doubt you would blow a head gasket, that comes mainly from overheating.
But its possible you could blow a ring landing off.
This is a good read that Disco started over at USMB, it has lots of input from people (me included) that have upped the boost on the EA82T.
http://www.ultimatesubaru.org/forum/sho ... hp?t=88249
Kralle
Post by Kralle » Wed Jan 13, 2010 3:45 am
okay, thank you for the answer, i think i will got up to 12psi, heres the intercooler i bought yesterday
http://cgi.ebay.de/ws/eBayISAPI.dll?Vie ... K:MEWNX:IT
hope it's big enough
I hope i will eliminate the overheating by mounting a second radiator-ventilator
Kralle
Post by Kralle » Fri Jan 15, 2010 7:05 am
in another forum some guys said to me i have to watch out for the engine characteristic map by using another turbocharger with more boost pressure, is that right? and how can i change the characteristic map? i know it isn't easy but is it needed by an EA82T engine?
Post by AlpineRaven » Fri Jan 15, 2010 7:23 am
Turbone wrote:I doubt you would blow a head gasket, that comes mainly from overheating.
ooh...
Reminded me of this - its off from another EA82T when he boosted it up too high.
