lamborghini-subaru
SCOOBIDOO
lamborghini-subaru
Post by SCOOBIDOO » Fri May 29, 2009 3:55 am
Here is some of my daily Grind to share....
I recently did a comprehensive inspection report on a lambo kit car, which had a 300hp v8 fitted, and a stall of around 3500rpm..
And guess what gearbox was used, look closely, thats right, a Subaru Leonie 3 speed auto with a modified bellhousing .
The road test .... It handle the power no problem, the internal,s were fully reconditioned,but still they are very tiny inside.
None the less, proving they are a mighty little transmission.....
Number plate,s read "WOT-THE"
THE FASTER THE SPEED - THE BETTER THE IMPACT...SUBARU
seagull
Post by seagull » Fri May 29, 2009 9:09 pm
I have built these gear boxes with Albins gears inside, dont worry it will go bang very soon !
they are Not that strong
seagull
Post by seagull » Fri May 29, 2009 9:13 pm
Now , this a 1600 cc auto as well . Extra clutch pack , plates ground on a light band surface grinder . The Ej20 n/a puts out just over 100hp , no skids > just the wheel in the air ~ !
d_generate
Post by d_generate » Sat May 30, 2009 1:22 am
Would someone please buy that horrid thing off Seagull, every time I go to his place I have to look at it.........YUK!!!!!!!
