if they are all similar then like was said on another thread on here go for a tune shop that you feel has good service, location etc and get their recommended ecu from them. then future dealings will be better.SuBaRiNo wrote:Yeah the thing is insane. I love it. I have no idea what injector/ECU combo im going to look at.
Seams difficult to get a straight answer out of any of the performance places as to a recomended ECU. They will only endorse what they sell and it seams no where sells all the different types.
It's all good for offroading now... where as before it was questionable. As far as it being safe... it's fine until the SC torque steers me into other lanes.
Dave
Hatch Supercharger progress
Yeah... there is that and i would also like to use a system which is easy to view and fault find... i don;t want to have to take it into the shop everytime a sensor stuffs about. So i would like something i can get hold of the software for and chuck it on my laptop.
Sorry no pics of the Bypass valves... and even if I did they would kinda be hard to see... they are rather hidden under the intake pipes.
Dave
Dave
- not12listen
AFAIK Dave is running a stock EJ22 with the supercharger bolted to the side of it...dibs wrote:just curious as to what other mods you have done .or was it a turbo moter to start with. if not how did you drop the compression .im thinking of a similiar thing
An accurate description Dave?
yes... only thing done is a recent rebuild. Depends who u talk to weather or not this is ok or not. Im only running low boost and i have not had any problems yet. There are A LOT of people that claim they know stuff about Superchargers but funny enough they all contradict each other. Trial and error is the best method.
Dave
Dave
theres heaps of thoughts on this sorta stuff.wether its suby holden ford or whatever .
my forced induction days are to fare back to remember. fummy thing is inhere someone once said they dont use a blowoff valve . iv seen a backfire on a 6 cyl holden with a stuck bov . the aftermath was bad. and yes it was mine.
what gets me is this electronic stuff. yrs ago i ran a blown injected 6 on the street .that was so easy so to speek . but nowwith ecus electronic injection ignition and the sort im bamboozld .
but i drive what i love and i gotta keep up with the times .
this is a gr8 site with heaps of info .someone always has advice or there opinion . gr8 cars new and old
thanks dibs
thanks dibs
diggin up a bit of an old thread
but chubby howd you go with the blown ej25
subarino
how did you go with an ecu
and do you have any better pics of that bracket showing the mounting points on the engine
i need to make something simaler to fit an sc14 to my brumby
subarino
- not12listen
dave, i'm curious...SuBaRiNo wrote:yes... only thing done is a recent rebuild. Depends who u talk to weather or not this is ok or not. Im only running low boost and i have not had any problems yet. There are A LOT of people that claim they know stuff about Superchargers but funny enough they all contradict each other. Trial and error is the best method.
Dave
how has the powerband changed? i'm guessing you have more torque in the lower rpms. but, at what rpm range does the supercharger become restrictive?
did you have to change or custom tune the ECU at all?
From what I can remember it didn't really become restrictive but did make a serious change in engine performace, I'm sure Dave can still torque steer through lanes on the freeway if he so desiresnot12listen wrote:how has the powerband changed? i'm guessing you have more torque in the lower rpms. but, at what rpm range does the supercharger become restrictive?
When I get my EJ in my L and become bored with it's output this would be the way I'd go too. Advantage is that the charger can be turned on and off like an air-conditioner compressor, I'm sure this is standard on most units, a good feature to have I think.
Probabily best to check out Tradewind's thread on his car - this is the post that you'll be after...
- d_generate
WRX Offroader taking shape.
Opps wrong thread.
- not12listen
my boss had a supercharged SUV - the supercharger was on constant. last i recall, the electro-magnetic supercharger setup is not common. i know for the supercharged mr2s (mki body style), they use the electro-magnetic style, though i'm unsure of the newer trd superchargers for the celica, matrix and trucks...El_Freddo wrote:From what I can remember it didn't really become restrictive but did make a serious change in engine performace, I'm sure Dave can still torque steer through lanes on the freeway if he so desiresDave really has done a remarkable job on Hatchie to create a very unique subaru off-roader...
- aussie_bob
