31"
31"
i managed to pick up cheap 15" rims that i plan on running, but attached to these rims are 31" tyres.
i have 3" lifted L and understand a little chop here and there may be required but can i get them in there?:twisted:
Short answer:  "no"
Slightly longer answer: Fatz has 6" lift kit, Subaru Outback struts, massive 2" wheel spacers, quite a lot of guard chopping, fairly wide offset rims....and the 31's don't fit - still can't get near full lock on turning.
I'm planning on running 29" tyres with my 6" lift kit, they should juuuust fit.
EZ30 L series - Monsterwagon
i hope ur good with a grinder
dave
dave
Hi mate,
I'm running a 3" lift with 215x80x15 which comes to ~28.5". I had to cut the front guards and beat the seam on the firewall flat to stop the rubbing. On the back it just catches on the rear of the wheel arch when hitting a big dip in the road.
Any bigger than about 29" you'd have to make major alterations to the firewall.
Hope that helps
Cheers Rob
Hope that helps
Cheers Rob
truth be told my car is mainly a daily driver and unless its some local urban mud my car just might not see it, with all this said all i wanted was 15" wheels with some normal road tyres.
but the 15" wheels were attached to the 31" monsters and after sitting them next to my car and wondering, i just had to ask? would be good... might still try.... my cars just asking for a yellow sticker even with out them.
i'll duck out side place one next to the car take a photo and up load it on here.
back in 5
back in 5
31s definatly wont fit with excessive chopping of guard and firewall. They fit fine stitting there straight, but as soon as u get spring compression and turning, it will rub like a mofo.
im planning on changin my 31x10.5 to 30x9. With the cutting that i have done, they should fit without any issues.
If you really want 31s prepare to massacre ur soobie, and get alot of unwanted attention.
As a daily driver thats just stupid, youll drink way too much fuel, and youll need a 4.44 ratio to get anywhere
hah, ill stick to my bfg 27's do the job well
 VER7 STI  (FOR SALE) & RIP     EJ22 AWD LEONE
Hunter S. Thompson
Hunter S. Thompson
Won't fit and you're wasting your time, - you wouldn't be able to have good steering in some corners.... *smash....
thats my 2c worth.
									thats my 2c worth.
