Loveday Riverland Challenge 2008
Heres a few of the highlights from the Riverland Challenge this year. Not all Subaru, but we're in there kickin it up with the big guys.
Earned ourselves a 2nd place in Sh**box class and won a few prizes.
See http://offroadingsubarus.com/lrc08.html for pictures and a little more info at showthread.php?t=11585
Hope you enjoy the vid and have a look at the others if your interested.
http://www.youtube.com/watch?v=wYkU9ys8Fvg
Only mine to my knowledge..
Its weird as the landing looks soft on my big jump, but on the inside it was anything but.
All good fun in the end anyhow. Brothers talking about maybe fixing it and taking it again next year. Should surprise a few people there if we do.
haha awesome! why isn't there one like this in Perth? WackyBug needs to go
First lap out we hit deep water (floated about 10" above the hard stuff at the bottom of the hole until we sank) and the engine cut. We had already plugged the hole on the disty and put in a "snorkel" for it, plus filled it with grease which is amazing how well it works. After we got pushed out the hole it started up ok.Matatak wrote:was your only trouble with front struts and tops?
We strapped the strut tops at the beginning, but on the second heat we hit the jump and broke a strap. Then fixed it, then broke again on the next lap with a jump. Then fixed it with 5mm thick plates welded to the tops, next heat which was sun morning I done the big jump and broke them again. Welded it up, then added some star dropper for more support. After that we took it easy until the finals which we hit the jump but didn't brake the tops off. Instead they fell out the bottoms and because the shockers were getting bent slowly it fell all the way out. Which is what finished our race in the finals.
Near the end the alternator was making weird noises. The Windscreen wipers were going 8 speed and one was only going half way up the windscreen. The lights were all on on the dash. And the extra washer motors had fried because of running without water.
Oh, and the other HUGE problem we had, the mechanical linkage on the secondaries were getting stuck on so had to put up with 7000 rpm around the whole track on most laps.
Mate, when posting youtube links just throw the link in without any tags or bottons. Like thisSubafury wrote:its called lancelin haha
http://www.youtube.com/watch?v=e9QpZznlDkA
- vincentvega
Fun, scary, and not so good for the engine. Tried to not use the clutch much to slow down, just a really heavy foot on the brakes
